Samsung Galaxy S5 Neo (SM-G903F) оснащен 5,1-дюймовым экраном Super AMOLED с разрешением Full HD. Устройство имеет две камеры: основную на 16 Мп и фронтальную на 5 Мп. Смартфон работает на 64-битном процессоре Exynos 7580, имеет 16 ГБ встроенной памяти, 2 ГБ оперативной памяти и аккумулятор емкостью 2800 мАч. Размеры устройства составляют 142 x 72,5 x 8,1 мм, вес — 145 граммов. По сравнению с оригинальным S5, Galaxy S5 Neo обладает улучшенными характеристиками, такими как фронтальная камера, наличие FM-радио и поддержка более быстрого LTE (Cat6).
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Замена дисплея Samsung Galaxy S5 Neo
http://www.sonymobilephones.com/samsung-...
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
из
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
из
Добавьте свой ответ
Kenny Leonard буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 551
