Shut off when in drive
When I start the truck it starts up fine but when I put it in drive it idles ruff then shuts off.. I have to keep gas on it
Это хороший вопрос?
Это хороший вопрос?
Jorge, Have truck scanned for trouble codes, some auto parts places offer code reading for free and may be a big help in diagnosing issue. It does sound like it could be a large vacuum leak. Check all vacuum hoses for cracks/loose/off. Use a can of starter fluid to spray around vacuum lines, intake manifold base gasket, throttle body, brake booster, etc. While spraying these areas listen for a change in engines rpm, it will change if there is a leak. Good luck.
Был ли этот ответ полезен?
I had this problem with my 2001 f150 lariat. the problem with was the mass air flow sensor (MAF) it would idle rough and cut off every now and then. I got some MAF sensor cleaner, removed it from the housing and changed the air filter for good measure. Sprayed down the sensor let it dry then re-installed the sensor. it hasn't done that since.
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За все время: 2,311
