Компактная камера Canon серии PowerShot A, выпущенная в 2006 году, с разрешением 6,0 мегапикселей и объективом с 4-кратным оптическим зумом.
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
из
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
из
Добавьте свой ответ
John Darago буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 676
