Хлебопечка 2006 или 2007 года выпуска
How to access timing belts
How to remove the covert to the timing belts on a BBA 2865 breadmaker machine
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Update (03.12.2022)
It cost me a lot of nerves to get the white plastic clips off. They are also a pain to clip back on later.
So finally, here the top is off, ready for the white plug to be unplugged:
The earth cable still has to come off:
Now take care of the on/off switch:
The switch cables can stay plugged in. Mine were so hard in, I feared to break them off. Just be careful.
Important for later assembly: the three spacers.
Now the way is clear to replace the timing belts.
Fixed. View from underwards:
Good luck! ;-)
Был ли этот ответ полезен?
Счет 4
3 Комментариев:
Great tutorial, helped me a lot on a BBA 2594 machine.
Thank You!
из
Thanks, it helped me too clatronic bba2865
из
Regarding the power switch:
it is easy to disconnect - gently pull the contact pistons (at the ends of the wires going to the switch) out of the switch's contact terminals
из
Belt is at the bottom of the machine.
You need to:
  1. Remove the inner heat shield. It has 8 screws at the bottom and one on the side wall which is holding the heater. Remove it gently.
  2. Remove the top of the machine. Do not need to remove the lid. Just open it, remove the screws caps beneath the lead. There are 5 screws. Unhuk 7 plastic hooks just below the top.
  3. Remove base with the circuits, motor and heater. Unscrew all 6 screws. Remove GND (green and yellow) wire. Disconnect mains power connector from the circuit board. Gently pull out the base, watch for the on/off button.
  4. Remove the broken belt or wheel. Replace the belt or wheel.
  5. Put everything back in reverse order.
Счет 2
Добавьте свой ответ
Pat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 1,187
