Флагманский смартфон Huawei 2016 года. Оснащен цельным корпусом и двойной основной камерой, разработанной совместно с Leica. Поставляется с вариантами накопителя на 32/64 ГБ и в шести различных расцветках. Номера моделей: EVA-L29, EVA-L19 и EVA-L09.
touch screen not working after screen replacement?
Hi everyone! i have a big problem. I've just replace the screen of my huawei p9 (it has been a VERY HARD work), when i've finished all, i connect all the cable, i turn on the phone, the screen work but the touch screen doesn't. What happen? how can it not work? i've done everything right...
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
hi, have you solved? Did you understand what the problem is?
I have the same problem and I am very worried because the phone is not mine but my brother and he is convinced that the touch screen does not work because I have not been able to fix it. I do not want problems with him. Please reply
Был ли этот ответ полезен?
Счет 0
Resurrecting something from the dead here but I’m seeing issues with a P9 myself. Touch is working but occasionaly unresponsive to swipes (especially left-to-right) or misinterprets swipes as touches.
Googling leads me to believe there’s a grounding problem or something. Or perhaps the part is just bad. I’ll try insulating the screen from the frame and clean the pressure contacts to see if it helps and update this with any new info.
Счет 0
1 Комментарий:
Hi... Any update?
из
Добавьте свой ответ
apriliamx5535 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 2,307
