Approach S2 — это элегантные и инновационные часы для гольфа с высокочувствительным GPS-приемником, который точно измеряет расстояние до передней, средней и задней части грина.
S2 no course near
Playing a course every wed last two weeks S2 said there was no course near. could you give me help with this. has worked prior to the last two weeks.
Это хороший вопрос?
Счет 4
1 Комментарий
My pc does not want to recognize the device and keeps requesting a format of the drive, but then cannot re-format via windows indicating read-only files etc?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi JMS,
I am currently expericencing the same issue, told by Garmin to buy a new watch ( best not type how I feel about that! )
Did you resolve the problem if so how?
Many thanks
Rob.
Был ли этот ответ полезен?
Счет 2
I have the same problem.
Had a lengthy online chat with Garmin. They were very helpful but the watch could not be fixed. They eventually gave me a code and said I need to use the code to buy another watch from them for 60 pounds (UK) as mine was out of warranty.
They said that perhaps I had disconnected the watch from my pc before completion of course updates (via Garmin Express). They said that even if Garmin Express states that the update was complete I should only disconnect via the hardware removal procedure (i.e. the 'safe to remove' feature) on my pc.
Счет 1
Добавьте свой ответ
jmslingenfelter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 2,348
