Отремонтируйте свой пылесос Dyson DC14 с помощью руководств по замене деталей.
Reassembly of brush orientation
I quarter turned the screws and exposed the roller brush to remove built up pet hair.
When I reassembled it, the DYSON DC14 turns on but the brush roller won't rotate and their is no bottom suction.
The extended wand has suction all of the time but not the power head.
I may have disoriented the endcaps on the roller bar and would like to know proper placement.
Also, why no suction there now and how do I fix that?
Debra R
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
ruthdebra55 , Sounds like the hose/channel to the power head may be plugged, remove power head brush and see if suction port clogged and also make sure canister is locked into position correctly. Find below a guide on the power head that shows orientation. Good luck.
Замена щетки Dyson DC14
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
No clogs (anywhere), proper assy (thanks for that) and still brush does not rotate.
It rotates manually without any extra tension and the belt seems fine.
из
ruthdebra55 , Thanks for replying back. Just a thought are you turning the brush control to the on position? There are 2 belts that drive the brush, the brush belt and the clutch belt. I will post a video showing how to change both belts along with a link to your manual for the DC14 which shows how/where to check when loss suction. Good luck.
https://www.youtube.com/watch?v=7_CtaFcc...
http://media.dyson.com/downloads/us/floo...
из
Добавьте свой ответ
ruthdebra55 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 36
За всё время: 5,407
