Furby — популярная электронная робототизированная игрушка, напоминающая хомяка или сову. После выпуска в праздничный сезон 1998 года она стала настоящим «хитом продаж» и оставалась популярной вплоть до 2000 года. В 1998 году было продано 1,8 миллиона экземпляров, в 1999 — 14 миллионов, а за три года оригинального производства объем продаж превысил 40 миллионов штук.
Furby thinks his shaking.
Furby thinks it shake in the vertical position and therefore always turns into the evil.
Это хороший вопрос?
Счет 2
2 Комментариев
Same problem with the 2012 furby model... It also wakes up by the minimal vibration he senses... I've searched online but I didn't found any comments about this problem...
из
I have the same problem since my 2012 furby decided to jump of my drawer when I wasn't looking
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
How to get your Furby to change personality?
Default Personality. All Furbies start off like this. You can get this personality back by turning your Furby upside down, holding down the tongue, and holding the tail pulled for 2 seconds.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
This isn't related to the shaking problem at all. The furby tilt sensor is probably at fault here. It's broken/too sensitive and even when furby moves by itself(while dancing etc) he thinks he's being shaken. But it doesn't have to work like that. For example as soon as I reset it it goes into the grumpy personality because he thinks he's being shaken. It also wakes up by itself after he fall asleep because the movement he does while he's closing his eyes it makes him think he's being shaken.
из
If your furby thinks it shaking while in the vertical position and switches its personality to evil/Feisty/ Viking mode. The furby tilt sensor is broken or too sensitive. For instance, if the furby dances, he may stop, since he thinks he's being shaken. I advise to take apart the furby to clean/replace his tilt sensor
This site might help even though it's for older Furby's:https://furbytech.tumblr.com/post/167541...
Счет 0
2 Комментариев:
Have you had any results fixing the issue in the 2012 furby? I'm having the same issue, and I found like 1-2 posts on reddit where people talked about not being able to fix it in their 2012 furbies / not being able to locate where the tilt sensor even is
из
@qhwohwfj I think I know which one is the sensor. It's the black "box" thing on the side of the Furby. On the pcb where there are others components. I actually thought it could be that when I disassembled the Furby a long time ago and I think there is a way to open it.
This site might help: https://furbytech.tumblr.com/post/174003...
or: https://learn.adafruit.com/furby-2012-te...
also: https://www.bot-thoughts.com/2013/03/fur...
This video is a full teardown so it may help as well: https://www.youtube.com/watch?v=DTp_gPqS...
There is sadly very limited information on Furby Tilt sensors out there.
из
Добавьте свой ответ
iambelkin13 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 1,783
