Выпущен в апреле 2013 года, номера моделей GT-N5100 (3G и Wi-Fi), GT-N5110 (Wi-Fi) и GT-N5120 (3G, 4G/LTE и Wi-Fi)
System UI has stopped
When trying to close apps on my note, I get the box that says, "Unfortunately, System UI has stopped>" How can I fix this?
Это хороший вопрос?
Счет 2
1 Комментарий
I can not find anything of one u beta on my phone and I have not had update for December that you hope to find in January that this is a rip off or not this is something like getting windows ten on your computer
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
I had the same issue. Found several suggestions. I did press "volume up" and "home" while powering on which brought me to a maintenance menu. I chose the clear cache option. That did not seem to do anything. Next I went to the "Setup" and "Apps". I found the app named "Google App", cleared its cache and then removed updates (reverting to the original version). After that things seem to work okay.
I assume "Google App" will auto update again at some point and we'll see what happens then. In the meantime, I was happy to find a way to get things working without having to do a complete wipe of the system back to factory default.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
This was so easy. Thanks so much for the help.
из Поделиться
Добавьте свой ответ
ltdeat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 25
За все время: 3,130
