Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
capslock flashing and black screen
black screen then caps lock keeps on flashing/blinking. one time i try to drain the battery then it works..but when this problem arises again it doesnt work again..i tried to remove the battery also..but still it doesnt work anymore..what should i do?
Это хороший вопрос?
Счет 1
2 Комментариев
I have. Problem in my computer compaq presario 061 its blink black pops on monitor when i used whats problem
из
My laptop compaq presario cq40 black screen with blinking under space bar help me
из
Добавить комментарий
1 ответ
Выбранное решение
This could be an host of issues any one of which can cause this so lets start with the basic. remove the laptop battery and disconnect the power then hold down the power button for 60 seconds. then reinstall the battery and plug in the power and boot the laptop. if it works it was a case of static discharge if there is no joy lets move on to the ram . Remove one stick of ram and try to boot the laptop if it doesnt boot then move that stick to a different dimm slot. and try to boot again if the laptop boots it means one stick of ram was bad if not then switch out and test with the other stick keep trying until you have tried each dimm in each slot . If you have no joy then we move on to the APU. try pluging in an external monitor. If it works then your LCD screen is bad and will need to be replaced if it doesn't work then the issue is probably with the APU. Hope this helps
Был ли этот ответ полезен?
Счет 6
2 Комментариев:
yes reinserting the battery while holding down the power button gives joy, but it's temporary joy. Actually it's annoying to do it repeatedly. What is the solution to make it normal?
из
replace the battery.
из
Добавьте свой ответ
rena ballesteros буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 17,052
