Nikon COOLPIX S9700 — одна из многих камер серии COOLPIX от Nikon. Она оснащена 30-кратным оптическим зумом и поддерживает разрешение 1080p, и все это в тонком, компактном корпусе.
How do I remove the lens
I have a mark on the inside of the lens of my S9700. I almost looks like a chip, but I'm hoping not, and can't see how that could have occured. I know how to remove the outer most cover by twisting to the left with the lens extended, and can see that the lens glass itself is suspended by the rest of the structure. There are 3 screws which seem to be holding this assembly in place, but having removed them I still can't lift off the lens structure easily, and I don't want to force it too hard in case there is something more I have missed. Any help would be appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@davidsain , David, Posted a couple links below, I think if you posted at first link the owner may have a break down of lens he might send you, 2nd link are a few lens break downs/schematics that you can click on and check out the info. Good luck.
http://www.johncaz.net/blog/how-to-locat...
https://www.google.ca/search?q=Nikon+Coo...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
David Plant буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 1,338
