power problem with my iron
Suddenly my iron has stopped working. The light doesn't come on and also it does not heat up. Please help me.
Это хороший вопрос?
Это хороший вопрос?
dumevisenyo , Since it appears not to be coming on at all, try a different known working outlet, if not that the plug/power cord may be faulty or could be burnt off at connection in the iron. See the link below, tear down guide for your Iron so you can disassemble and test/check all wires/connections/switches/contacts/etc., visually and DVOM, to see if you can determine what has failed. Good luck.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 6,400
