How to fix the F11 code?
How do I fix the F 11 error code on my washer?
Это хороший вопрос?
lindsay.harman F11 is an indication of a communications problem between the machine control board and the motor control board. Possible causes:
Loose wire connection at either the machine control board or motor control board.
Machine control board failure
Motor control board failure
Door lock
Motor
you could try a proverbial hard reset by following the procedure below.
To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 10-20 minutes.
Reconnect the unit to the power source by turning the breaker back on or plugging the washer back in.
Press the Pause/Cancel/Stop button twice to clear the display.
Download the service manual from the bottom of this page and let us know if and what works and what does not.
Был ли этот ответ полезен?
I had this problem last year. Called Sears and they right away said of it is the board that needs replacing. So they ordered the board. $600.00. Well they came back two seeks later to replace the board. And they did not have the part said it was being mailed to our home. We never received it.Well the washer started working when we got home after gone for a month. Never received the message again. Until this week. Decided to call a local appliance person. He immediately took off the front bottom part. Asked for a pan and towel. He drained the water pump. You can’t imagine what came out. Built up lent and the smell. He could not believe how old my set was 15 years old. He stated they looked brand new. I wash about twice a week. Just two of us. So it cost us $140.00 instead of replacing the board. He stated that is what most people immediately do replace the board. Glad I called him instead of Sears
Thanks for your story. I was visiting an elderly couple who’s washing machine was giving F11. I cleaned out the water pump trap and all is well! The service man was going to charge them $600 to just replace one of their boards. Ridiculous how people take advantage of the elderly. Thank you!
I just went through the same problem with wash interruptions due to F11 codes on my Kenmore He3t. Sometimes I would show the dl (door lock) code as well. Tried snugging electrical connections and the plug/plug in techniques and managed to limp along for a while that way. After checking for pricing on a new washer control board ($210 best price) I opted for a remanufactured one through Ebay fulfilled by Partsimple.com for $81. The part arrived two days quicker than the estimated delivery, installed easily and solved my problem/s. The part number is 8181692.
Hi I have the same problem. checked everything. still not working. machine starts filling up and then the F11 code starts beeping. what next please. thanks
Had this exact problem. My Kenmore elite is 20 years old. I ordered the new housing communication panel part number 46197030068 off of eBay watched a YouTube video of how to change it out and voila operating normal and no code. All for $280 with 3 year warranty. My family kept saying just get a new one but I was determined to fix it. What did I have to lose. Thanks for the information.
Shan
Hey... I just wanted to add to this forum. That F11 is tricky because it IS a disconnect to the motor, but where. I bought a $50 used Kenmore Elite H3t off of Craigslist that had the error. $50. We don't have a lot of money so have to usually work with what we have. Luckily I was able to fix the old one... No CPU!!!
As for these crappy CPU ones.
I replaced mother board returned it because it was not that. Got an F24 after that, emptied the pump... Lot of crap in there... Finally thought it was the wires so checked each line and found one that wasn't working. Turned on and effing F11 error again. Tapped out and pulled it apart for scrap and found something...
Board for motor was burned out..... Son of a.... Well I scrapped metal, have a cool motor and other items I will try to move on Craigslist. Wish me luck and thanks... Almost got there...
i drain out the water and particules on the filter at the bottom of the washer and connect it again to power and the door unlocked and is running again.
I found that code only came on because of socks that got stuck inside the bottom drain hose. If you open the bottom door (2 screws) pull off the door you have to unscrew the pump cover and I found numerous things inside. I reconnected everything took the drain hose off, cleaned it out and put it all back together. No codes since easy fix. That got rid of both F02 and F11 codes.
За последние 24 часов: 1
За последние 7 дней: 18
За последние 30 дней: 133
За все время: 83,772
2 Комментариев
I have been getting the F11 code off and on for a while now. I checked on the motor control board wiring/made sure they were all snug. I ran the diagnostics and everything seemed to work fine. I started a load and got the F11 code again. If there was a board failure, would the diagnostic test run okay? I don't want to spend money one something that doesn't need fixing. Any help would be appreciated.
из Amy McDurham Поделиться
I have a Kenmore Elite H3t front load washer. I had F11 error and cleaned out the drain plug like people mention on here but still F11.
I bought the part 8181692 and installed. Now I get an F99 error which is saying I have the wrong board, but the numbers match. Help me Obi One washer expert... You are my only hope.
из James Avondolio Поделиться
