Руководства по ремонту и техническая поддержка для третьей версии 5D — зеркальной цифровой камеры, выпущенной Canon в 2012 году.
err 40 at power up
Hi,
my camera 5dmk3 power up correctly but it returns err 40. could it be an issue related to the PCB bottom or the DC-DC PCB, what's your opinion regard it?
I tried to load / access to your canon eos 5d mark 3 parts catalog , but it does not loaded. Is it in progress or is it not available?
Thanks in advance
Giorgio
Это хороший вопрос?
Счет 1
Добавить комментарий
5 Ответов
Выбранное решение
Giorgio Ba err40 is most commonly an electrical error. It can be related to the battery (first thing I'd replace) but also with the flex cables going to the DC-Dc board etc. Not sure why the parts catalog does not download for you. Added it on here==>>EOS 5D Mark III Parts Catalog
Был ли этот ответ полезен?
Счет 1
Hi Giorgio.
Did you find out what was wrong?
Rune
Счет 0
Hi,
Problem- A power malfunction have detected.
DIY- Turn off the camera and after 15-20 seconds power it on.
Счет 0
Was you in wet condition (moisture, raining, etc.) and after that camera´s went to faulty?
Счет 0
The bottom flex cable, between the bottom and main board, if installed backwards, can cause this error. The end with a B on it should be on the bottom board.
Счет 0
Добавьте свой ответ
Giorgio Ba буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 19
За последние 30 дней: 38
За все время: 4,692
