Xperia Z1 Compact — это премиальный камерофон от Sony. Он похож на модель Xperia Z1, но меньше и дешевле. Его ключевая особенность — 20,7-мегапиксельная матрица. На момент выпуска устройство было доступно в белом, черном, розовом и лаймовом цветах.
Данное устройство можно идентифицировать по номеру модели (D5503).
Customer came in with he's Sony Xperia Z1 Compact where the power button was not working and the volume buttons was barely working. So i told him i will order the flex cable part and get it fixed.
When i opened the phone i first checked if all that was needed was just to attach the plastic bit holding the flex cable into place a litle more. But still didn't work. So i went ahead and changed the flex cable.
After the change, the button still won't work. I checked and double checked my work and all seems normall. I also tried changing the button flex cable again.
Now the phone won't turn on and the buttons are not working.
Most important is to get the phone on without losing any files.
Anyone have any ideas, suggestions or solutions? it would be most greatfull.
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
I tried and looked at all the steps in your post and all seems well. The phone shows the Sony logo if i put in the charger but getting it to turn on as the power button won't work is not going well.
Open the sim card tray you'll find small red button besides tray press it using pen tip till handset vibrate. Now your phone will be turn on without losing your files.
2 Комментариев:
Thanks for your answer. We already tried that and unfortunatly it was not successful.
2 Комментариев
@oldturkey03 Thanks for your answer.
из Total Repairs AS Поделиться
Did you find the root cause?
из Paul Carew Поделиться
