Toughbook CF29 Screen Replacement
Is it possible to replace the hole display of a Toughbook CF29 without opening an breaking the seal?
Thx
Это хороший вопрос?
Thx
Это хороший вопрос?
I do not think that this is possible. The only way would be to replace the whole top part, however, your cables will have to be disconnected on the inside of the panel. So I guess you will have to split the halves and reseal them after. Personal I think you will do fine with some silicon after as suggested. Good luck
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 24
За всё время: 1,547
1 Комментарий
I have the replacement part numbers if you need them to your toughbook.
just post the full model number (example: CF-29C3KGZ1M)
из S0U1SB4N3
