earphone socket not working
I bought my BlackBerry z30 before 5 months earphone jack is not working. How can I solve this?
Это хороший вопрос?
Это хороший вопрос?
@balanagaraju , bala , Try a reset, Press and hold volume up and down button simultaneously and letting the phone restart or Press and hold the power button till the phone restarts.
Try a different compatible set of earphones(a lot of aftermarket type may not work), look inside the jack for dust/lint/etc., pick out any you see and then blow out with canned compressed air. Go into your phones setting to be sure not muted,etc. if alllooks good possibly the jack is faulty and will need replaced. If only 5 months old return for repair/replacement/refund. If not worried about warranty you could also dissmantle the phone(link below) and check and clean the connection/check for damage, reassemble and try. Good luck.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За все время: 988
