Информация по ремонту смарт-часов Garmin Vivoactive HR. Выпущены в феврале 2016 года. Номер модели: 010-01605-03.
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
Это хороший вопрос?
Счет 5
1 Комментарий
Hey everyone,
Best regards,
Cesare
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Hi Andreas,
I have a used display. Are you still interrested?
Был ли этот ответ полезен?
Счет 2
7 Комментариев:
Is the used display still available?
из
Yes is still available
из
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
из
Hi.
May I know ifthe display still available?
из
Leonidos didn't answer me. See my Question above...
из
Показать ещё 2 комментариев
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
Счет 1
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
Счет 0
2 Комментариев:
How did you get the screen off? Trying to get it off without completely destroying the unit.
из
It’s being hold down by adhesive tape so use heat
из
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
Счет 0
Good to know for future, but in not much more you can buy used but working device :)
Счет 0
Добавьте свой ответ
Andreas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 29
За все время: 5,215
