Игровая консоль от Sony Computer Entertainment, также известная как PS4. Анонсирована 20 февраля 2013 года и выпущена 15 ноября 2013 года в США и Канаде, и 28 ноября 2013 года в России. Модель CUH-10XX, 11XX, 12XX
How to fix the Fan header
I was disassembling my ps4 and got down to the fan header. I thought that you had to pull the cord horizontally and did that without knowing that I had to do it vertically. So then I accidentally broke the fan header but was able to repair it, temporarily, with the ps4 shutting down most of the time due to overheating. I want to know if there is a permanent solution to fix the fan header, so then I don't have to play with it all the time to keep the fan running.
Это хороший вопрос?
Счет 3
2 Комментариев
Can you post pics
из
this will help with posting a picture
Adding images to an existing question
из
Добавить комментарий
3 Ответов
Выбранное решение
It sounds like you must be talking about the fan connector on the motherboard. If that's the case then you have several options:
1) Solder the fan wires directly to the correct pins on the motherboard
2) Replace the connector...if the connector on the motherboard itself is broken then you would have to probably get a connector from a junk motherboard. If it's the connector on the fan side you could just replace the fan.
3) You could purchase a new motherboard...this option is obviously not the best since it's so expensive but it is an option.
I hope this helps. Good luck!
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Hey Steve, I have been trying to buy a new set of fan headers (10 pieces) from Ali Express but they sent the plugs from the fan side NOT the sockets I thought I ordered, now they have blacklisted me from buying anything because I returned the wrong items! Where do you suggest I can source the correct item(s) as I am in Australia and it is hard to get parts for consoles? Looking forward to help.
из
This happened to me but it was on the fan side. I just discarded the plastic and connected the cables directly to the mother board without having to solder. PS4 1100 series
Счет 0
1 Комментарий:
How did you manage to do this?
из
I did it with a needle it lifted it and slides out after
Счет 0
Добавьте свой ответ
Astrowings230 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 6,112
