Выпущенная в 2014 году камера Samsung WB350F оснащена 21-кратным зумом и модулем Wi-Fi.
Why does my camera scroll through the menu?
My camera continually scrolls through the menu when I turn it on and when I push the button to take a picture. Often, even when I push the button to take a picture, I cannot take the picture because the camera is scrolling through the menu, and this is visible on the display.
Это хороший вопрос?
Счет 4
5 Комментариев
I have the same problem. ronaugermd@gamail.com
из
Camera constantly scrolls.
из
It's a great camera except it continues to scroll preventing taking a picture.
из
Same problem, and Samsung can’t even help… even though it says right on the box “PLEASE STOP AND READ CAREFULLY: If you experience technical when operating your Samsung digital camera or if the camera is not working properly, please contact the Samsung technical support center for assistance. PLEASE DO NOT RETURN THE PRODUCT TO THE STORE WHERE IT WAS PURCHASED. Our expert technical support team will evaluate the problem and provide the service your product requires. Please call 1-800-SAMSUNG (726-7864).” I called and was transferred to a guy who didn’t even know that technical support was SUPPOSED to deal with cameras. (*rolls eyes*)
из
REMOVE THE BATTERY ... REMOVE THE BATTERY, PRESS THE POWER BUTTON 5 TIMES ... THIS REMOVES ANY RESIDUAL POWER IN THE CAMERA .... CLEAN THE ROTERY SWITCH (camera top right corner) WITH ISOPROPOL ALCOHOL ON A COTTON SWAB OR COTTON BALL ... DRIP SOME ALCOHOL INTO THE CREVICE BETWEEN THE ROTERY SWITCH AND THE CAMERA BODY, ROTATE THW SWITCH A DOZEN TIMES IN BOTH DIRECTIONS AND ALL WILL BE FINE ...
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Found this: https://www.youtube.com/watch?v=_OyccVWY...
Temporary fix for a manufacturing defect.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Basically, you just put a few drops of isopropyl alcohol around the base of the functions dial and then you work the alcohol in by turning the dial (switching functions) for about 30 + seconds. Be sure to TAKE OUT YOUR BATTERY FIRST and decharge the camera after taking the battery out by pressing on the on/off button a few times.
All this does is clean out the dial, and the camera works again. It is a temporary fix. But at least it works.
из
this worked for me, do not be afraid, no damage occured ... camera works as it should after cleaning the rotery switch ...
из
Використовував цю інструкцію для розбирання Замена экрана Samsung WB350F
Потім змочив у спирті ватну паличку і вставив у сервісний отвір
Після чого провертав колесо “Меню” проти годинникової стрілки 30-60 секунд.
Після даної процедури, збоїв не спостерігаю вже близько пів року.
Счет 1
2 Комментариев:
This fixes the problem of broken buttons for the menu, not the above problem of the dial.
из
на фото червоними стрілками вказано, де треба чистити.
из
Счет 0
Добавьте свой ответ
Jackie буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 57
За все время: 1,639
