Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
Это хороший вопрос?
Это хороший вопрос?
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
Был ли этот ответ полезен?
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
За последние 24 часов: 8
За последние 7 дней: 24
За последние 30 дней: 94
За все время: 17,795
2 Комментариев
I have this problem too.
из Maggie Asberry
Same problem! I have tried everything to get the end cap off two pairs of pliers, the hairdryer thing some I cannot get it to budge!!
из Donna Jean
