Tablet shuts down while playing games
Tablet shuts down while playing games. Tablet also will not open games app. - just closes automatically. Comes up with a box that says Thermal Shutdown. Thermal critical error occurred.
Это хороший вопрос?
Это хороший вопрос?
Your tablet is overheating.
If your tablet is in case, try taking it out. I have the same tablet and it tends to get hot and shut down.
Also, try some type of cooling pad or something that will allow air to get to the underside . That should help remove any build up of heat around it.
If it is heating up right after starting up, then you may have some internal problems. You might want to look into having someone look at it or finding a new tablet.
Good luck.
Был ли этот ответ полезен?
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 24
За все время: 1,150
3 Комментариев
How do I fix this problem
из rdollen1 Поделиться
Check the chosen answer for what you’re looking for.
из Eric Viitala Поделиться
how do i fix this on amazon kindle fire gen. 5
из Albert Einstein Поделиться
