Более крупная модель ноутбуков MacBook Air от Apple, оснащенная двумя микрофонами и поддержкой Wi-Fi 802.11ac.
How to replace the Arrow keys (bottom)
My Macbook Air (A1466) has lost functionality to the down arrow key, I am not sure if it is missing a part or can simply be snapped back in, It won't actually snap in as the clear (white) bracket is on my desk. How do I get it back in? I don't see a guide for this and every youtube video seems to reference a different model or other keys that are not the same as the arrow keys. In fact, the up key is also different than the down key mechanism having taken it off for reference.
Thanks.
Update (03/29/2017)
Hopefully this is a good reference. Should there be a mechanism (spring) on both sides or just one?
Thanks.
Это хороший вопрос?
Счет 1
6 Комментариев
Do you need the plastic button replaced or the button on the logic board
из
Do you have the little rubber nipple still sticking up? It would be the part right under the Key. If this is missing the only thing you could do would be to replace the entire TopCase or just use an external KeyBoard.
из
yes, the rubber nipple is there. It appears that my part is different from the OEM. Received this as hand me down. Can you acquire replacement keys?
из
I believe you would need to order the replacement key from Apple. I'm looking into it now to see if there is another place. If you lived in Oklahoma I would say bring it to our shop we have tons of parts computers. Can you press down on that nipple and get the key to work? If not then a replacement key isn't going to fix it.
из
There is a place called Replacement Laptop Keys - MacBook Air you should be able to get the replacement key parts from them.
из
Показать ещё 1 комментарий
Добавить комментарий
1 ответ
Выбранное решение
If the key is no longer working when you press it, buying the plastic key will not restore functionality. You will need to replace the whole keyboard to resolve this.
Two options;
1. Replace just the keyboard, easier to mess something up https://www.youtube.com/watch?v=2PyhbiwU...
2. Replace the palmrest where little can go wrong for a beginner Замена верхней части корпуса MacBook Air 13" (середина 2013 г.)
If the key is functioning when you press the rubber spring, you will just need the keycap and mechanism, which you can find on Google or eBay by Googling "a1466 key" and comparing to the layout of the original mechanism.
Был ли этот ответ полезен?
Счет 1
8 Комментариев:
If he is missing the key then it could still work this is why I asked him to try the nipple to see if it is working when pressed. If he presses on the rubber nipple and the key still doesn't work then yes definitely a replacement TopCase needed.
из
@iceplow that's why I gave him all of the options. Sounds like it is not working, since he says "My Macbook Air (A1466) has lost functionality to the down arrow key"
из
@iceplow - It looks like the keycap lost the clips to hook onto the scissor mech, If depressing on the rubber the action works then thats whats needed.
из
@danj good eye, will just need the keycap if it all works fine then :)
из
LOL Lord have mercy! I'm pretty sure I asked him if when he presses on the nipple if it works or not from there We can all take turns telling him if he needs a TopCase or another key.
из
Показать ещё 3 комментариев
Добавьте свой ответ
Brad Osborne буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 10
За последние 30 дней: 86
За все время: 15,816
