Аккумуляторный гравер от компании Dremel с различными настройками скорости и возможностью установки насадок.
Collet Nut Frozen on Shaft
I have not used this Dremel tool in some years. The Collet Nut is frozen to the shaft and cannot be loosened to insert bits. How can I loosen this? Short of replacing the entire shaft? I have already soaked the part in coke and it has not loosened.
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Выбранное решение
A lot of these had a button which locks the shaft in place allowing you to put pliers on the collet and turn it. See if yours has such a lock.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
No kidding. That's the problem... the locking button does not hold the shaft in place and it slips out.
из
@knightowl12 ,Jeffrey, If collet lock button not holding sufficient, you may have to disassemble the Dremel(link below) which will allow you to access the shaft which you can put vice grips on to hold the shaft while using pliers/vise grip on chuck to loosen collet(if able put a couple drops of penetrate oil to run down bit to collet jaws for 30 min. before starting the repair).
Разборка Dremel 8200
Счет 1
Добавьте свой ответ
Jeffrey D Sage буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 61
За всё время: 12,922
