Micro-USB power port is broken
The micro-USB power port on my NES classic broke. Is it an easy fix, and where can i get a replacement port?
Это хороший вопрос?
Это хороший вопрос?
@wackowax ,Waqas, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide/vid. to get you inside the Nintendo Classic Mini NES to check the charge port and will also post a link(not your device) showing what is involved in repairing a mini USB attached to the board. You can do a search for replacement port or you may have to try visually matching it up(may be standard type). If not wanting to attempt the repair have a couple good local game/computer repair shops have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 31
За всё время: 3,804
