Asus ROG Strix GL702VM-BHI7N09 — это игровой компьютер, выпущенный компанией Asus в январе 2017 года.
Should I replace my battery?
It seems like the battery life of my laptop just continuously gets worse and worse. It doesn't last as long as it did when I first acquired the laptop, and I'm worried that it won't get any better or stop anytime soon. Does this happen with laptop batteries?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
This is a pretty common issue with laptops, though often the issue isn't caused by a bad battery. A common cause for short battery life is old or outdated software. Old software tends to absorb battery life faster than the new updated software, while sometimes causing lower overall computer performance also. Try updating to the latest software and see if that helps your battery issue. If this doesn't fix the issue, you might have to replace the battery. Check out the troubleshooting page for the Asus ROG Strix GL702VM-BHI7N09 for more information.
Hope this helps!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Samuel Porter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 27
За все время: 1,902
