Dell Venue 8 — это планшет среднего ценового сегмента на базе Android, выпущенный компанией Dell в 2013 году.
Part of the screen is black
I dropped my dell venue 8 tab and a part of the screen has gone black.The screen is intact but that one part of the screen remains black no matter what I do.Can someone help me with this?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
arzoo arzue, Sounds like a damage LCD. Below is a guide(2nd link) to enable you to get inside device to check and reseat connections in case this is the issue. If screen still not working properly the LCD screen is probably damaged and needs replaced. 1st link is a replacement display if needed, which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.parts-people.com/index.php?a...
Замена дисплея Dell Venue 8
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thank you so much for your help.:)
из
arzoo arzue , Your welcome thanks for replying back and feel free to select answer as your solution. Good luck with your Venue.
из
Добавьте свой ответ
arzoo arzue буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За все время: 350
