Why bike wont start
I have a 2013 thunder bird 1600cc sometimes starts with no problem, and other times power to gages and fule pump but when i hit the starter nothing not even a click?
Это хороший вопрос?
Это хороший вопрос?
@hectorpez ,Hector, That could be signs of a battery on it's way out or bad connection. Have battery tested, check all connections and wires for not being loose/corroded/damage in the starting circuit/on battery. See the link below as it discusses your issue. I have also attached a down loadable service manual at the 2nd link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 29
За всё время: 3,282
1 Комментарий
Check for correct gap of sparkplug (s) and proper plug size
из Robert Johnson
