Housing for Nikon D70
Hi!
I have a Nikon D70. Not using the model since the display lcd size is too small to review the images taken.
Is there any way to change the display size or will any other Nikon body fits the D70 body?
Это хороший вопрос?
Hi!
Это хороший вопрос?
You can set the image size and quality through the Nikon D70’s settings menus. To sum up the Image Size and Image Quality information available to the Nikon D70:
To adjust the settings, you have the following choices:
For more information please check Nikon D70 Manual.
Был ли этот ответ полезен?
The LCD on the back cannot be replaced with a different or larger one, and it is not possible to move the system into a different body shell that has a larger screen, as the circuit board/system is not designed for a larger screen.
The D80 I know didn’t have the ability to output to an external screen live, so doubt the D70 had it, as that would be the only other option if you need the screen larger.
A new body would be better, as there is other improvements to the other parts of the body other than the screen.
За последние 24 часов: 3
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 410
