Руководства и информация по ремонту бензиновых скутеров с объемом двигателя 49 куб. см.
No start on electric starter
My scooter starts fine with kick starter but has no spark when I try to use electric starter.
It has new battery and ignition coil and plug.
Turns over fine just won't catch
Это хороший вопрос?
Счет 3
2 Комментариев:
@lawless sounds like a wiring issue. What make and model is your scooter?
из
My scooter is a hover one eagle and so when I got it and it didn't turn on I started troubleshooting when I opened up the display unit in the neck I found that there was a set of wires not connected it has a black connector and there's five wires to it there is nowhere that I have found in the neck or the display unit that these wires hooked to
из
Добавить комментарий
3 Ответов
I have a Yamaha tweet 50cc kick start works but not electric starter l have new battery new starter botton n spark plug what else can it be
Был ли этот ответ полезен?
Счет 0
Check for spark at your spark plug. Replace after testing the CDI. (Capacitor Discharge Ignition) Replace coil wire. Check the starter relay with a voltmeter. Next check the voltage regulator. The last worst-case test is your Stator. Can also be your timing is off. I just performed all these steps except replacing the Stator but that tested alright with the meter. I still think 1 of the New ignition wires is grounding out my kill switch, ran fine until I replaced the New Ignition Module Assembly because I lost my keys. I will post when I resolve Which Wire is the Problem.! P.S. Electric start working fine now after changing some wires around on the ignition( New 1 has 5 wires and only 4 connect. The kickstart will not start it though, barely turns the engine.
Счет 0
1 Комментарий:
It's an electric kick scooter guys sorry
из
Comment réglage carburateur
Счет 0
Добавьте свой ответ
Phil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 49
За всё время: 2,903
