Asus Q501LA оснащен процессором Intel Core i5 4200U (1,60 ГГц).
laptop has burn component
hi there i have an issue with my laptop,there is a burned component near the LCD connector and near the battery connector hope someone can send me a clear picture of it so that i can replace it manually
Это хороший вопрос?
Счет 1
3 Комментариев:
Can you send a picture of the burnt component? It would be easier to see the damage than to guess.
из
@haron09 post a couple of images of the component as well as where it is located on your board. Use this guide for that.
из
DrGlowire did you see the picture below
из
Добавить комментарий
1 ответ
hi DrGlowire here is the picture
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
by the way this motherboard is for ASUS Q501L hope someone can reply and solve this issue,i need that that component so that i can replace it thanks.
из
Добавьте свой ответ
haron medina буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 475
