HP Pavilion dv6500 — это доступный мультимедийный ноутбук с экраном 15,4 дюйма, стильным корпусом и сканером отпечатков пальцев для безопасности.
Why does my screen not displaying
It seems like the screen backlight is up but no display other than the blank dark screen....
Это хороший вопрос?
Счет 0
Добавить комментарий
4 Ответов
Наиболее полезный ответ
This problem can be either the laptop display or the GPU/motherboard. You can test the GPU by connecting an external monitor, if the monitor displays then the problem is in the laptop display. The laptop display could have a problem with the back light, if you shine a bright light onto the display and you can see icons on the desktop then the problem is the back light. If all you see is blank then the problem is the laptop display.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Thanks for your answer but I have tried using another monitor but still no display...
из
The problem is the GPU on the mother board.
из
HP laptops are tops soldered at the factory, meaning they are baked.
A temporary fix if it dies on the road is using a hair dryer.
The permanent fix is by rebaking it.
https://www.youtube.com/watch?v=G65-ncBx...
Счет 1
1 Комментарий:
Thank's to Michael Otero for his video.
из
You can also try this for a reflow procedure.
http://www.deskdecode.com/how-to-fix-a-l...
Счет 0
You can use reflow to fix ANY top soldered board including automotive and television applications.
Счет 0
1 Комментарий:
Not always. Most of the time yes, but there are exceptions
из
Добавьте свой ответ
Nsikan Udotung буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 19
За все время: 1,022
