Nikon COOLPIX B500 — это компактная камера среднего класса с суперзумом. Она выпускается в черном, фиолетовом и красном цветах.
Camera Wont turn on PLEASE HELP
nikon coolpix b500 power button will flash green for a second when pushing the button but will not stay green and camera will not turn on
Это хороший вопрос?
Счет 18
29 Комментариев
I have the same problem. It would say battery exousted and then I just stopped turning on. I've had it for 6 days. What is going on? I'm very sad
из
I also have the same problem :(
из
I have the same problem. Could be batteries, but this last time i changed batteries and it still remained unresponsive. Christmas present. Only used a couple of times.
из
This has happened to me too. It was working fine the day before but when I tried to turn it on to see my pictures the day after it won't turn on. I've only had this camera for about a week.
из
I bought another Coolpix. Took it out of the box and it won’t zoom. It says to turn the camera off and turn it back on. I’ve had it for about 2 months now and it has never worked. I just photoshop the pics later. Frustrating!
из
Показать ещё 24 комментариев
Добавить комментарий
6 Ответов
Наиболее полезный ответ
I had this problem i changed my batteries to brand new ones and it turned on. Hope this helps. :)
Был ли этот ответ полезен?
Счет 7
3 Комментариев:
Yes, changing the batteries and making sure they were new ones did the trick! Thanks!
из
I tried that several times but nothing. I cannot even get my lens back in. I just got it and i just started using it this week. It worked this morning. Very frustrating
Im on vacation and cannot plug it in
из
I changed out batteries; no difference. Then I took a Q-tip and wiped inside the battery silos and then wiped clean the contact plate on the battery door. VOILA!! Maybe the batteries, maybe dirty contacts. But it worked!! Today's date: Oct. 5, the wonderful year of 2020.
из
Take a Q-tip and, if you have it, dip in white vinegar. Remove batteries and clean the contact points in the camera. If no white vinegar, try cleaning without it. It worked for me!
Счет 2
The Nikon CoolPix B500 is a current model, perhaps a known issue with this model.
I would recommend a warranty repair, chances are Nikon will ship you a new camera as it's less expense for Nikon at times than an actual repair.
Счет 1
3 Комментариев:
Im on vacation so i cannot bring it anywhere
из
Nikon use to be the top of the line of camera. I will NEVER buy another one
из
tried that several times but nothing. I cannot even get my lens back in. I just got it and i just started using it this week. It worked this morning. Very frustrating, I buy new batteries but nothing
из
Need new batteries. I have Nikon Coolpix B500 and it works.
Счет 0
I was facing the same issue and the reason i found to keep cells inside the camera for longer time .due to this camera cells connectors got some smug and also not able to charge cells properly .
It is just like keeping for car in garage and not drving for longer time
The quick solution is open the camera cell lod and takeout the cells.
Keep the both camera and cells in direct sunlight for 1 -2 hours.and put the cells back in camera.
Mine camera is working now.
Счет 0
I just had this same exact problem and it turns out I was using carbon zinc batteries in my camera when the Nikon coolpix b500 only takes lithium or alkaline batteries. They are definitely more expensive but last longer. Check to see if this is your issue
Счет 0
1 Комментарий:
I tried using SnapBridge in order to download pictures. But now the camera will not start! Each time I press the on button, it lit up once and turned off.I tried to paired it with my cell and it kept on searching. Wonder if I could have the camera reset it to original setting?
из
Добавьте свой ответ
brittany_371 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 23
За последние 30 дней: 135
За всё время: 40,649
