battery contacts points missing in cover
how can I replace the battery contacts points in the cover
Это хороший вопрос?
Это хороший вопрос?
@fasteddywilson, edmund, Normally the battery door assy would be replaced as it will have the contacts molded into it I believe. Below is a guide that will show how to disassemble camera to access battery door hinge pin to enable changing of battery door. Also a couple links to replacement battery door assy. which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Замена корпуса камеры Canon PowerShot A620
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 16
За последние 30 дней: 23
За все время: 615
