Dyson V6 Motorhead — это легкий беспроводной пылесос. Он легко трансформируется в ручной пылесос для уборки, а вместо сменных мешков для мусора в нем используется удобный контейнер.
Why is my Dyson not working?
my Dyson inst working and i have no clue why? how much would it cost to be looked at and fixed and who can i take that to?
Это хороший вопрос?
Счет 1
2 Комментариев
Please give us a description of its symptoms. What will it do and won't do.
из
only a year old-used maybe 10times-suction for 2 times , then I went back to using my $50 Shark-was going to throw it out then saw it was guaranteed for 2 yrs. Purchased 5/14/16 Where can I take it for repair? Most expensive vac I've ever had & never worked well.Tried my neighbor's first & his is old & still works fine. TY
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
I would first suspect a bad battery. When you put it on the charger, does the light(s) glow? If you have access to another battery, try it. If that fails, the power button or wires to the battery have broke or failed. Use the below guide to check that out.
Замена мотора Dyson V6 Motorhead
Был ли этот ответ полезен?
Счет 3
Just tell me where I can get it repaired? My cheap Shark is almost 3 yrs old & works fine.
Счет 0
email answer to Granniejude@aol.com
Счет 0
My vacuum it works for a short period of time and stop. How can I fix it?
Счет 0
Добавьте свой ответ
taylah woollard буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 19
За всё время: 3,133
