Выпущен в августе 2013 года. Определяется по номеру модели Z796C.
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
Это хороший вопрос?
Счет 9
4 Комментариев
I also have this problem and can not find an answer.
из Поделиться
Yes help me remove message
из Поделиться
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
из Поделиться
My phone doesn't allow any contact to save
из Поделиться
Добавить комментарий
3 Ответов
Наиболее полезный ответ
go into your setting and enable the permissions for your contacts..should be in application settings
Был ли этот ответ полезен?
Счет 5
4 Комментариев:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
из Поделиться
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
из Поделиться
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
из Поделиться
How do I find the contact applications so I can all he permissions?
из Поделиться
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
Счет 0
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
Счет 0
1 Комментарий:
On cell majestic. Zte
из Поделиться
Добавьте свой ответ
Elena Vaccaro буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 18
За все время: 8,211
