Why it won't charge anymore?
It won't charge anymore. I have tried other wires. My iPhone charges. So I know it's the charging port.
Это хороший вопрос?
Это хороший вопрос?
I would suspect that the iPod's battery is dead seeing as how this unit is probably 5 years old. iFixit doesn't sell the battery but a quick Google search should point you in the right direction. I would follow this guide for the replacement. Keep in mind that the battery is soldered in place so it will require some soldering skills to complete the repair.
Был ли этот ответ полезен?
I read somewhere to look inside the charging port to see if it's dirty. I poked in a toothpick, and a piece of lint came out. Problem solved!
That's exactly what was the issue with mine! There was something in there. I put a toothpick in there and worked it out. Thanks for the tip!
I just fixed mine doing the same thing! There was a piece of lint or something in there!
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 36
За всё время: 10,393
