Первая модель iPhone. Модель А1203; с 4, 8 или 16 ГБ памяти; и алюминиевой задней крышкой. При ремонте придется помолиться и немного попаять.
How to replace the glass only?
Has anyone tried this? Found a 25 dollar 1st gen in good condition on eBay and I would like to get it but it has a cracked glass. LCD is fine. Does it have LOCA? It is like the 3G/3GS screen?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Due to the design of the iPhone, the glass cannot be replaced seperately from the LCD panel. The glass and LCD are fused together during manufacturing and cannot be separated. Both the glass and LCD panel must be replaced as a unit.
iPhone 1st Generation Display Assembly Replacement
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
Could I remove the dock connector?
из
@mayer is correct. The average user can't replace the glass on it's own. This is not a DIY job.
It can be done with the right equipment, new glass, a UV light and LOCA glue but it's probably something you aren't capable of doing.
из
I have done LOCA replacements before, they were not perfect but they looked a lot better (a spec of dust got in the screen) Also, I just bought the phone.
из
Добавьте свой ответ
Gigabit87898 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 181
