door unable to open
Can a maytag bottom freezer in a duel electronic cool refrigerators tracks freeze and make the door unable to open?
Это хороший вопрос?
Счет 0
2 Комментариев
Ice forming underneath freezer prevents freezer door from being able to open
из
@rontp
What is the model number of the freezer?
из
Добавить комментарий
2 Ответов
Выбранное решение
The tracks freeze warm outside air has entered the freezer causing condensation. The door can be hard to open for a lot of reasons. Tracks require bearings to be greased regularly. Common causes are Too much food causing poor air flow-something got lodged - drawer off the rails/track-door didn't shut completely allowing warm air in n created large ice mass. The freezer door should be opened only by pulling the middle of the handle. Pulling from the side at angle will throw it off. To realign, remove all food from freezer, grease bearings, slowly close then open completely the firmly shut
Был ли этот ответ полезен?
Счет 2
Наиболее полезный ответ
Possibly, what's the history on this unit? Is it a known leaker? Was it previously owned by someone from the government? Those are known leakers.
Счет 2
4 Комментариев:
Mayer, Government owned refrigerators are known to leak? I don't work near a base, but that's good information to know. I'm curious, what's the reason for that?
из
@ladytech I believe that @mayer is referring to the government personnel when he speaks of leaks ;-)
из
@ladytech Sorry for confusing you. Mike is correct, it's political commentary.
из
Mayer, that's funny! You got me with that one! :) I had a blonde moment. :)
из
Добавьте свой ответ
Shannun Westling буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 22
За все время: 442
