Стереонаушники серии MDR-ZX100 ZX производства Sony.
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Ремонт разъема 3,5 мм наушников Skullcandy SCS-SCBP SKULLCRUSHERS to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Ремонт Sony MDR-ZX100 and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERS Изображение
Инструкция
Сложность:
Умеренно
45 minutes - 1 hour
Sony MDR-ZX100 Изображение
Инструкция
Сложность:
Умеренно
15 - 30 minutes
Был ли этот ответ полезен?
Счет 1
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
Счет 0
Добавьте свой ответ
nitheesh k буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 369
