Смартфон Sony Xperia Z5 Compact на базе Android оснащен 4,6-дюймовым IPS LCD-дисплеем с разрешением 720 x 1280, четырехъядерным процессором Qualcomm Snapdragon 810 и 2 ГБ оперативной памяти. Выпущен в октябре 2015 года.
Notification led blinks 4 (four) times?
I was have problem with my lcd: there was picture but no backlight.
Then;
1-Pulled off battery
2 -Cleaned flex cables with alcohol.
3-Putted everyhing back.
4-Putted battery back.
5-Tryed to power on.
Now:
When i try to power on vibrates 1 time as normal and 5-6 seconds later red led blinks 4 (not three) times. No thing happens. If i try to shut down by sim slot button its acts normaly and vibrates 3 time.
Anyone knows what is the meaning of 4 time led blink.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Sony Online Support emloyees made me crazy. I find my own answer. When lcd or backlight is broken or cant work properly device prevents boot up. 4 time blinks wants to say that! Thanks for Sony's ignorant employees.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
i disassbemled my lcd's flex cable and phone booted up normaly (without picture of course.). I will buy new lcd.
из Поделиться
Did new screen solved the problem ?
из Поделиться
What is an icd?
из Поделиться
I replaced the LCD screen and back camera. Now it won't boot up. There is no response at all from any of the reset option. The 120 second reset. The power+volume up, power+volume down. Nothing. When I connect to charger and hold down the power button, the red LED comes on for a second, then turns off, the phone vibrates 3 times followed by the red LED turning on again for a second and then turning off. Then the process repeats. Holding down the power or the 120 second restart button while plugged in yields the same results. I tried repair using pc companion, doesn't work.
Счет 0
Добавьте свой ответ
mehmed akif ay буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 20
За все время: 5,125
