Голосовое устройство Amazon с поддержкой Alexa Voice Service. Модель S04WQR.
EchoDot Not seeing Bluetooth Devices
My EchoDot has stopped seeing and connecting to my Bluetooth speaker or to my Bluetooth earphones.
Both the speaker and earphones are seen in the ALEXA app on my iPhone.
The problem started shortly after I had added the new earphones. The earphones work OK with my iPhone (play music, etc.). I do not try to join both devices at the same time. Bill D.
Это хороший вопрос?
Счет 0
3 Комментариев
My echo dot 4 cannot find bluetooth speakers since… yesterday????
I had some Logitech bluetooth speakers working fine until yesterday’s night. Now I cannot pair again.
из
im having same problem. Ive tried setting up the alexa on my phone again but it wont show my phone as a device to pair with on bluetooth.
из
Same here, I got a new phone and Alexa couldn’t play radio, music or find the previously connected speaker. Have cleared all settings and connections, re-installed the app, uninstalled the app from previous phone. Everything is now working apart from connecting to the speaker. Baffled!
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
If echo dot stopped and unable to seeing Bluetooth speaker then see following what to do:
- Open your Alexa App on which device you are using.
- Hit Settings.
- Tap on your Echo device, Select Bluetooth and Clear all paired devices.
- Re-pair the devices, say "Pair "commands around Alexa to place the Echo in discovery mode.
- Next, head to the Bluetooth settings on your device or app in order to pair, as normal.
Был ли этот ответ полезен?
Счет 5
5 Комментариев:
Alexa can't find any bluetooth speakers when i want to add new devices. She can only find them when I want to add them to the Alexa Echo. But then I can't add individual devices to different groups/rooms. They are all in the same room and all under Echo Dot.
из
didnt fix it didnt fix it didnt fix
из
Worked like a charm, lol was gonna return it till I saw this post. Thanks!
из
This hasn't fixed it for me either. I have no paired devices and now I can't connect any devise via Bluetooth to my echo dot
из
Same here. Was working fine. Suddenly stopped. Tried to re find the devices but it sees nothing at all now. This is for all 10 of my echo speakers. What did they to on the last update?
This was reported in 2022, just happened to me last week September 2023 Needs a fix urgently
Amazon tech are you listening!?
из
New permissions on android check settings, apps, permissions, Alexa, nearby devices.
Счет 0
I had the sane issue and after fighting with it for a while I figured out that I had ROKU app installed and they seem to be incompatible with each other. Basically you can have one or the other but if you pair them first then use them for the ROKU app then the dot cannot find them. So I uninstalled the ROKU app and they found them no problem.
Счет 0
In my situation near by devices was an enabled permission on the Alexa app. I had to disable that permission and re-enable it so that I could see my bluetooth devices for pairing.
Счет 0
1 Комментарий:
That did not work for me 😕
из
Добавьте свой ответ
wdesmith буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 23,836
