Процессор Intel Core Solo 1,5 ГГц, Core Duo 1,66 или 1,83 ГГц, либо Core 2 Duo 1,83 или 2 ГГц. В этом разделе представлены первые модели Mac mini на базе Intel, выпущенные в период с начала 2006 по середину 2007 года.
Why does the Fan run continuously?
Primary Symptom:
•The Fan runs loudly at full speed, and stays on all the time, as soon as the computer is booted.
Other Symptom(s) or Details:
•All operations of the machine seem to be slower than they used to be, whether using just the OS, or running an application (I do not know if this is a related problem).
•80GB HD with 47GB free space. 1GB RAM installed. Computer is used *only* for email, internet browsing, and to run Finale (music notation software - no audio processing)
Это хороший вопрос?
Счет 2
2 Комментариев
Have you check if your fan cable is insert correctly in the cable channel? Open your mac mini and make sure to connect the fan cable!!!
из Поделиться
Has the machine been upgraded or taken apart recently? There is a sensor at the front of the machine for the hard drive, if it is not reconnected back the fans will run at full speed as soon as the machine is powered on.
из Поделиться
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Possible you forgot one cable in the back of the Mac Mini.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Exactly what it was for me. Thanks for posting the picture as well cause once I saw it, I connected the cable.
из Поделиться
Exactly me too! Thank you!
из Поделиться
Download, install and run TG Pro to be able to locate the problem:
https://www.tunabellysoftware.com/tgpro/
Счет 1
Heat sinker must be cover with thick dust and the fan is working overtime to keep it cool. Open unit and with a compress air can blow it clean. Some of the current drawn by the fan pull resources from other components (CPU, video, USB, etc...) slowing everything else.
Счет 0
Добавьте свой ответ
Ed Maceachen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 22
За все время: 4,613
