How can I unlock my iPod
My little sister was play with it and lock it. I forgot my combination and can't unlock it.
Это хороший вопрос?
Счет 6
2 Комментариев
ive down loaded some music and turning it back on its showing the padlock feature and i cant unlock it ...how do i unlock it
из
It may also be called _volumelocked
из
Добавить комментарий
3 Ответов
Выбранное решение
Here is a link to Apples procedure for setting and removing the lock. Please note you will lose all your data. Good luck.
http://support.apple.com/kb/ht1350
Был ли этот ответ полезен?
Счет 2
Наиболее полезный ответ
rj713 is of course absolutely right. There is a also another way to reset it without losing the data from your ipod :
first plug in the ipod, go to my computer, click on the ipod drive. Go to tools > folder options then click view. Click show hidden files,
Go to ipod_control, then go to device. There should be a file named "_locked" delete that. Now unplug the ipod and you should be ready to go
Good luck
Счет 4
4 Комментариев:
didn't work so don't konw
из
it did not work
из
This Helped Alot Thank You
из
It worked for me thank you a lot.
из
Go to Ipod folder in computer make sure hidden files are displayed
go to
-ipod_control
--Device
---_locked
don't delete it, just change it to un_locked
worked for me many times, just don't know how to full remove code or change it without restoring ipod
Счет 1
2 Комментариев:
Telling her how to show the hidden files would greatly improve your answer.
из
This actually worked for me! In explorer go "View > Hidden Items" and uncheck it. Then go to the folder "IPod_Control" and do as described above.
из
Добавьте свой ответ
melissa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 15,230
