Krups Espresso Mini — это паровая эспрессо-кофеварка, предназначенная для домашнего использования.
To remove corrosion or rust.
Hello, I am using KURUPA 963 / A. This boiler is made of aluminum, the inside of the boiler has been corroded like a photo, how do you keep the body from harming people and how to remove the corroded parts? thank you.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I'd try some CLR on it first.
CLR is a powerful formula for dissolving tough calcium and lime deposits and surface rust stains from tubs, toilet bowls, sinks, glass, chrome, fiberglass and stainless steel. CLR is septic safe and contains no phosphates.
https://www.walmart.com/ip/CLR-Calcium-L...
Был ли этот ответ полезен?
Счет 2
Is the boiler actually corroded (Metal is partially dissolved due to chemical reactions), or do you have lime deposits from hard water? If the metal is corroded, then there is little you could or should do, short of replacing the boiler.
One way to judge what you are dealing with is where the discoloration is - if it's mostly where the water is, and expecially where the water gets hot (at the bottom of the boiler), then it is most likely lime deposits. If the deposit is grey and more or less everywhere, then you might have chemical corrosion going on.
If it's lime, then you might be able to dissolve it with a strong citric acid solution. You can find citric acid in the canning aisle of a reasonably well-stocked supermarket or hardware store. Use the stuff that people use in their preserves, Dissolve as much of it as possible in distilled water (again, supermarket), and run it through your espresso maker. After that, rinse with lots of water - a couple of runs, I'd guess. This should help, and should be food safe
Счет 2
Добавьте свой ответ
caddibo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За все время: 1,988
