Смартфон Sony Xperia Z5 на базе Android был выпущен в октябре 2015 года. Sony Xperia Z5 оснащен 5,2-дюймовым дисплеем с разрешением 1080 x 1920 пикселей, процессором Qualcomm Snapdragon 810, 3 ГБ оперативной памяти и основной камерой на 23 Мп.
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
Это хороший вопрос?
Счет 5
1 Комментарий
can i turn off that sensor that make the screen black when covered ?
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
из
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
Счет 2
3 Комментариев:
Thanks for this very helpful information
из
Omg it works thank you!!!
из
2023 still using this trick. Tq very much
из
I have that problem also
Счет 0
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
Счет 0
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
Счет 0
i just pressed the top righthand corner and the screen came on !!!** weird or what
Счет 0
Добавьте свой ответ
Char Duffett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 12,150
