Модель 1996 года была представлена на Североамериканском международном автосалоне в 1995 году и построена на платформе Chrysler S.
car will not move in reverse.
So i have a 97 dodge caravan 2wd 3.3ltr i was backing out of my driveway and it hesitated befor moving but moved about an hour later i got in and put it in reverse and it would not move. Pressed on the gas a little and it still wouldn't move all other gears work and fluids were checked and are good. I can feel it shift into reverse but no movement and when the gas is pressed it rev's and sounds like it puttered like it was about to backfire. Any ideas?
Это хороший вопрос?
Счет 0
2 Комментариев:
Is the an automatic transmission or a stick shift?
из
Automatic transmission
из
Добавить комментарий
1 ответ
I would double check those fluids remembering they should be checked warm with the engine running after shifting into all gear options. If this does not work you may have an electrical problem preventing all the necessary solenoids from activating. Your best shot may be to drive it to a repair shop and have them diagnose it. If it is only the solenoid the fix shouldn't cost that much.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Sky Simpkins буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 1,919
