Это Android-устройство LG было выпущено в октябре 2015 года. Номер модели устройства, использованного для создания этих руководств — LG-VS990.
My phone has a bootloop problem
My phone has a bootloop problem and i tried to repair myself. The repiar was successfull but after two of working, the issue started again.. so i repaired it agian and aftr the cleaning the dust inside my phone, i small chip was hanging to the motherboard.. Well, I know i f**d up, now i want the original LG Motherboard for LG V10 at&t.. Where can i buy the replacement?
Thanks in advance!
Это хороший вопрос?
Счет 2
3 Комментариев
i checked that before,but i need the original motherboard..not the replicas
из Поделиться
Fixed wife's V10 after it constantly rebooted. I work for CameraSecurityReviews.com in Indiana as a repair technician servicing audio and video equipment like this http://camerasecurityreviews.com/4-chann... . The root cause of this reboot issue, and sometimes overheat issue found in G4,G5 and V10...is a ball-array mounted IC on the main PCB on the screen side of the board. Its a larger IC without the interference shield over it.
The fix involves heating the IC and PCB with hot air and allowing the solder underneath the re-flow and make a connection again. Don't melt any plastic connectors. Also take out any SD card and the SIM card so they won't melt! Hope this helps someone.
из Поделиться
I baked my motherboard. Worked like a charm. Using it for more than a daynow with no issues.
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi!
You could try hereor here.
Был ли этот ответ полезен?
Счет 5
3 Комментариев:
@oscarsp @yvaneck jkingsnorth sorry but no SPAM here. Just a couple of benign links to a replacement board.
из Поделиться
Thanks for the warning @oldturkey03 , but I vote as not spam. The links help to solve the problem and I know that @alexniculescu is a good assistant does not send spam. I apologize if I made a mistake marking it.
из Поделиться
@oscarsp it's all good. Not a warning just making sure helpful answers are not being misunderstood :-) No apologies necessary
из Поделиться
Добавьте свой ответ
Anche Karthikesh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 19
За все время: 12,615
