Второе поколение смартфона от компании Fairphone, основанной на принципах социальной ответственности. Выпущен в декабре 2015 года. Номер модели: FP2-XCVR
Is my battery out?
I bought my Fairphone 2 in June , and just recently my battery would not charge anymore. Could it be out already, or can it be another problem?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi @ elolinon,
if you connect your charger to the phone, would it start after you press the power button or is only the notification LED red flashing?
In case only the LED is flashing, your battery could be discharged under a certain value where the charger won´t start the charging process.
That doesen´t always mean the battery is defective.
With a Multimeter you can measure the cell voltage.
Is the Voltage above 3V you can charge it with an professional external charger to above 3.8V.
Then the charger in the Fairphone kicks in again.
In case you do not have the equipment you can go to a repair cafe or to a RC-modell hobbyshop.
My battery(almost 2years) is still running because of this.
Try to end app processes which will deplete the battery to this state (eg. GPS navigation overnight on)
Or try this without equipment:
https://support.fairphone.com/hc/en-us/a...
Был ли этот ответ полезен?
Счет 1
My barely 3 year old Fairphone 2 has become VERY slow - also when fully charged! Any suggestions for troubleshooting?
Счет 0
Seems to be software related.
Try the following guide.
Dont forget to backup your Data.
Счет 0
Добавьте свой ответ
Elin Österberg буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 19
За все время: 963
