HP OfficeJet 4630 — это беспроводной цветной струйный принтер «все в одном».
Always shows error of paper jam
As soon as the device is powered on the printer shows error paper jam. Full disclosure this issue started to happen after a cat peed on it. It worked for a couple of days and now it is showing the same error again
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
cat pee is acidic. this must have caused some parts in the board to corrode and shorted out
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Firstly, why did the cat pee on it?
Secondly, since something is shorted you should check for anything that seems broken and replace it.
из
Was house sitting a friends cat. He must have been confused or something to something so random.
I suspect something similar too. Will have it checked.
I was hoping that I might discover a simple hack that can resolve the issue.
из
Добавьте свой ответ
Nishit Rao буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 16
За все время: 1,013
